Should I use an ebay step-down module to get the voltage from a laptop power supply to 12V?
Discussion in 'Power Electronics' started by FranciscoB, Jun 29, 2016.
  1. FranciscoB
    Feb 8, 2014
    22
    I'm looking to replace the old fluorescent bulb lighting of my small aquarium (10 liter). Led strips are readily available and I have a 16V Asus laptop power supply with a broken connector. I would like to ask if I can use one of these modules to step it down to 12V:
    http://www.ebay.com/itm/1pcs-1-23V-...dule-LM2596-Power-Supply-Output-/400985220074
    I already have one of these LM317 circuits. Could it be used instead?
    Led Strips (I would not be using the whole 5M, maybe 4 sections of 40cm positioned side-by-side but in series):
    http://www.ebay.com/itm/5M-300LEDs-...-Lights-Super-Bright-Waterproof-/231472954932
    Power Supply:
    http://www.ebay.com/itm/19V-AC-Adap...452904?hash=item43d337b7a8:g:rpgAAOSwiCRUc~U4
    Thank you in advance
    /F
  2. FranciscoB
    Feb 8, 2014
    22
  3. Lestraveled
    May 19, 2014
    1,957
    1,218
    I think it would work fine. I would go with the LM2596 switching converter.
  4. dannyf
    Sep 13, 2015
    2,196
    417
    Get a sense of the current consumption of the LEDs. If it causes significant dissipation over the lm317 (5w or more), I would consider alternatives.
    Also, understand how the LEDs should be powered.
  5. FranciscoB
    Feb 8, 2014
    22
  6. Dodgydave
    Jun 22, 2012
    5,150
    769
    Yes use the Lm2596, you can get a ready-made one on ebay..
  7. FranciscoB
    Feb 8, 2014
    22
    Thank you.
    (Go Reds! \o/)
    Dodgydave likes this.
  8. Colin55
    Member
    Aug 27, 2015
    204
    21
    You don't need full brightness. Just put two lengths (same length) in series.
