Should I remove heatshrink from thermocouple
Discussion in 'General Electronics Chat' started by Markd77, Feb 10, 2013.
  1. Markd77
    Thread Starter Senior Member
    Sep 7, 2009
    2,803
    594
    My multimeter came with a thermocouple, but I noticed that the heatshrink tubing says 125 degrees C on it. I think I found the datasheet for the tubing:
    www.mantech.co.za/datasheets/products/S901-2_SALIPT.pdf
    and the multimeter (not much useful information in there):
    www.mastech.com.cn/down/MS8221 series.pdf
    I'm worried that the tubing will turn into a smoking mess if I use it for temperatures of 300C or so. The white part of the cable feels like glass fibre or similar so I think that should be OK.
    Should I cut the heatshrink off?
  2. thatoneguy
    Feb 19, 2009
    6,357
    718
    I'd remove it, for all you know, behind it you'll find a blob of solder connecting the couple to the wire. :eek:
    jaygatsby likes this.
  3. #12
    Nov 30, 2010
    16,665
    7,313
    The heat shrink tubing is trying to keep the fiberglass from unraveling. If you remove it, you should try to think of something that will accomplish that job and survive 300C, like, teflon.
  4. Markd77
    Sep 7, 2009
    2,803
    594
    Thanks, I got rid of the tubing and wrapped a little iron wire near the end of the fibreglass (I didn't find any solder in there). Just measured my soldering iron at 280C and the fibreglass, or whatever it is, seems fine with that.
  5. #12
    Nov 30, 2010
    16,665
    7,313
    Good job!
  6. mcgyvr
    Oct 15, 2009
    4,787
    973
    so funny to me..
    400 deg C. rated meter/TC but yet they stick 125deg C UL rated tubing on it.
    That "glass fiber sheathing" is probably just nylon string/cord too.
  7. Markd77
    Sep 7, 2009
    2,803
    594
    Yes, pretty funny. The soldering iron doesn't melt the sheath, so I think it is probably the right stuff.
    I'm glad I spotted it, but as it was essentially free with a fairly cheap multimeter, I'm not really bothered.
