Should I attached metal chassis of the filtered powerline module directly to the Faraday cage?
Discussion in 'General Electronics Chat' started by Dong-gyu Jang, Feb 21, 2016.
  1. Dong-gyu Jang
    Jun 26, 2015
    101
    Hello.
    I'm using AC power entry module filter (http://www.mouser.com/Search/Produc...irtualkey69300000virtualkey693-DD12.4111.1111, DD12.4111.1111, Schurter) to construct the Faraday cage to protect circuit against strong EM wave during gas discharge experiment.
    So far, the module is inserted to the cage with insulator such that ground of the module (so signal ground of the circuit) is not directly connected to the Faraday cage as intended for the circuit not to be affected by possible fluctuated voltage of the cage.
    However, I read some article which seems suggest that the signal reference of the circuit and corresponding shield are to be at the same ground. Yeah maybe in this scheme, voltage of the cage and circuit's ground are the same so no current can induces between them but...Is it really good idea for strong EMI environment? If so, why? My vision is shaking between original thought and this...new finding.
    Please give me clear view of shielding.
    Thanks!
  2. Dodgydave
    Jun 22, 2012
    5,172
    779
    A Faraday cage requires that it be connected to the mains earth supply to prevent RF radiation from penetration to the outside world.
  3. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,712
    1,303
    Yes, connect the power line filter ground to the chassis or cage. In this way the metal can of the filter helps to cover the hole caused by the plastic power connector.
    ak
  4. Dong-gyu Jang
    Jun 26, 2015
    101
    Hello.
    The main earth supply means powerline to the circuit to be protected? Does it mean The Faraday cage and the powerline filter should share the same ground?
  5. Dong-gyu Jang
    Jun 26, 2015
    101
    I see. The direct metal contact is necessary to minimize hole.
    Then..what about coaxial cable adapter? I'm using coaxial cable (BNC) to communicate the circuit to the other instrument through the cage and currently isolation BNC adapters (http://www.mouser.com/Search/ProductDetail.aspx?R=3846virtualkey56520000virtualkey565-3846, 3846, Pomona Electronics) are used. This one has insulation thus no direct contact from this to the cage but it seems you suggests fully contact for all other components.
  6. Picbuster
    Member
    Dec 2, 2013
    391
    53
    This may answer some of your questions;
    http://www.elmac.co.uk/meast_t.htm
    http://www.thomasnet.com/articles/automation-electronics/effective-emi-shielding
