Should a Varistor have continuity?
Discussion in 'General Electronics Chat' started by Gdrumm, Jul 26, 2015.
  1. Gdrumm
    Thread Starter Distinguished Member
    Aug 29, 2008
    684
    36
    A big screen TV that someone threw away, and I am trying to fix it.
    Immediately after the 110 v plug (power in) there is a Varistor.
    I haven't pulled the board yet, but I tested for continuity across the two leads of the Varistor and I get no beep.
    Doesn't that mean its blown / failed / open?
    Gary
  2. Alec_t
    Sep 17, 2013
    5,969
    1,135
    A continuity test shouldn't cause a beep, because a varistor has much greater resistance than, say, a fuse. Try it on the Ohms range of the meter. The varistor is presumably an inrush current limiter whose resistance drops as it heats up.
  3. dl324
    Mar 30, 2015
    3,377
    651
    Varistors are transient voltage suppressors. They're only in their "low" resistance state when they're conducting. A beeper or ohm meter can't put a line voltage MOV into a conducting state...
  4. Gdrumm
    Aug 29, 2008
    684
    36
    Can I connect a voltage through it, via my Variac to test it?
  5. crutschow
    Mar 14, 2008
    13,482
    3,369
    Not ideal. Better to measure the voltage across the varistor when you try to turn the TV on. If it's the full line voltage, then the varistor is bad.
  6. DickCappels
    Aug 21, 2008
    2,766
    667
    As pointed out in another recent thread, Varistor are very rugged and difficult to "break" because the physical construction is little more than a block of ceramic with two electrodes. When varistors fail, it is usually spectacular. If you can read the part number on your varistor, it is almost certainly good.
    A beep from a DVM, particularly a single beep probably means that it had mistaken the capacitance of a component for resistance.
  7. Hypatia's Protege
    Mar 1, 2015
    2,845
    1,311
    @Gdrumm
    Inasmuch as non-CRT TVs have no use for degaussing circuits, the likely application for said varistor is line-surge protection -- Such a varistor (specifically an 'MOV') will appear 'open' under normal conditions, whereas a low resistance reading is indicative of failure (and should be accompanied by an open OCP fuse/breaker)
    I'm confused -- It seems to me an High-Z (i.e.'undeployed') MOV would drop the full line voltage across its terminals --- Is there an implementation I'm unaware of?:confused::oops:
    Genuinely intrigued
    HP
  8. MikeML
    Oct 2, 2009
    5,451
    1,066
    You guys need to agree on what you are talking about. Is the device wired in series with the AC line, or in parallel with the AC line? Is it wired as an in-rush limiter or as a spike suppressor?
    Hypatia's Protege likes this.
  9. Hypatia's Protege
    Mar 1, 2015
    2,845
    1,311
    Now I get it!:) --- Thanks @MikeML!!! :D:D:D
  10. MikeML
    Oct 2, 2009
    5,451
    1,066
    My questions still are unanswered. I dont think the OP knows or knows the difference...
  11. Hypatia's Protege
    Mar 1, 2015
    2,845
    1,311
    Without a schematic I suppose there's nothing for it but 'tracing' the circuit...
    Best regards
    HP
