Should a Bridge Rectifier read 0 Ohms in any direction?
Discussion in 'General Electronics Chat' started by Fred1451, Oct 3, 2012.
  1. Fred1451
    Oct 3, 2012
    I have a piece of equipment that is tripping breakers as soon as it is turned on. I was pointed to a bridge rectirfier as the probably cause of my problems. My meter does not have a diode test function so I tried reading resistance. I have opens between every pin except between the '+' DC pin and one of the AC pins. Is that supposed to be there, or have I found my problem?
    Thanks.
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    Have you taken the bridge rectifier out of the circuit?
    If the bridge rectifier is still in the circuit the transformer will measure like an almost short.
    Take a look at this page how to measure diodes with a DMM:
    http://www.allaboutcircuits.com/vol_3/chpt_3/2.html
    Bertus
  3. vk6zgo
    Jul 21, 2012
    677
    85
    You may also find it helpful to read this thread on p2 of this forum:-
    Full bridge rectifier
    P.S On second thoughts,you probably have found your culprit.
    In a normal circuit using a transformer,there will be a short between the two AC inputs,but there should not be one between either of the AC inputs & the positive output.
    The bad news is,that if you have AC on that rail,you may have killed some components.
    Thanks for the link,Bertus.
  4. Fred1451
    Oct 3, 2012
    I had the bridge completly out of the machine.
  5. ErnieM
    Apr 24, 2011
    7,443
    1,628
    It's worst then that, he's dead, Jim.
  6. ramancini8
    Member
    Jul 18, 2012
    447
    119
    Check for a shorted filter capacitor or you might blow another diode bridge when you fire it up.
