Shortwave broadcasting migrating to satellite...
Discussion in 'General Electronics Chat' started by Externet, Nov 6, 2014.
  1. Externet
    Thread Starter AAC Fanatic!
    Nov 29, 2005
    780
    58
    Hi.
    My habitual shortwave listening mainly from european radio stations is slowly being phased out in favor of satellite broadcasting emissions.
    I believe it is called Digital Audio Broadcasting DAB.
    What receivers brands/vendors are on the market in USA or Europe ? How do I search for decent ones ? Any of you have one ?
    Please do not tell me I would have to pay Sirius or XM to receive them...
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
  3. crutschow
    Mar 14, 2008
    13,505
    3,380
    Except for pay services such as Sirius/XM, I think all other DAB broadcasts are terrestrial.
  4. Externet
    Nov 29, 2005
    780
    58
  5. nsaspook
    Aug 27, 2009
    3,016
    2,375
  6. crutschow
    Mar 14, 2008
    13,505
    3,380
    Yes, that's what I meant.
  7. Externet
    Nov 29, 2005
    780
    58
    Good ! Can you explain if yours or useable LNBs are the same ones I could find canibalizing discarded DirecTV and DishNetwork equipment usually in route to a dumpster ?
    Slowly learning the lingo, what is NA ? --> North America ? Is HH horizon-to-horizon ?
    I have a 8' Unimesh dish, am after a receiver and the LNB, plus a lot of knowledge. Can you guide me for a convenient receiver that will get Galaxy 19, 17 at 87 and 91 degrees for DVB and also DAB ?
    Are those LNBs with multiple waveguide heads at fixed angles, meant to select another satellite without need to re-orient the parabola ?
    Are those multiple heads meant for the commercial suscriber providers only, working with fixed spaced satellites ? Which would you recommend for FTA ?
  8. NorthGuy
    Jun 28, 2014
    611
    121
    What is the highest antenna which looks like a pole with 4 thin sticks coming out if it?
  9. nsaspook
    Aug 27, 2009
    3,016
    2,375
  10. nsaspook
    Aug 27, 2009
    3,016
    2,375
    Your dish will work for KU band but might need a little modification for the LNB mount.
    I use a QPF-031 on my dish as I needed to use the original feed-horn to optimize the signal as the dish is moved but the QPH-031 or similar LNB will work nicely on a dish with 40mm clamps for most FTA stations. If you don't have a dish mover then a multiple LNB mount will work with closely spaced birds like at 87/91.
    Original Primestar LNB with feedhorn: http://www.cs.cornell.edu/w8/~eckstrom/802.11a/primestar/01a-primestar_feed_horn.jpg
    http://invacom.net/documents/Quadpolardatasheetwhite.pdf
    https://www.google.com/search?q=mul...6KOLuigL1nIHYBQ&ved=0CEkQ7Ak&biw=1270&bih=847
    I can't recommend a current receiver as mine are pretty old (Viewstat Xtreme/SatPros) or use internal PC DVB cards to receive stations.
  11. NorthGuy
    Jun 28, 2014
    611
    121
  12. NorthGuy
    Jun 28, 2014
    611
    121
    New ones are LNBFs for Ku-band. Some of these LNBFs are for circular signal, some for polarized. Find your provider's satellite on http://www.lyngsat.com If you see letters R and L next to the channel frequency, this is a circular signal. If you see H and V, this is polarizied. For FTA, you need an LNBF for polarized signal.
    People say that if your mesh is coarse (e.g. you can put a pencil through it), you won't get Ku-band on it. However, you definitely can get C-band on 8'.
  13. nsaspook
    Aug 27, 2009
    3,016
    2,375
    It mainly feeds an old RS PRO-2006 scanner with some frequency band/scanning mods.
    http://www.monitoringpost.com/pro2006/2006rev.html
    I also use it with a SDR usb receiver(RTL2832U interface IC & R820T tuner IC on USB dongle) but that's normally connected via a up-converter to a SW antenna in the attic or the FM antenna for music.
    http://www.amazon.com/NooElec-Ham-I...d_sim_e_6?ie=UTF8&refRID=1ZZXN6P3PCHATY56M52C
    https://flic.kr/p/dYB4q5
