Shorting out VCC to VDD when measuring with a meter
Status
Not open for further replies.
DexterMccoy
Joined Feb 19, 2014
429
Why does a plug in bench DVM meter ( 3 wire AC plug in DVM meter ) short out when measuring VCC and VDD at the same time?
VCC is +30volts and VDD is -30 volts
The Bench DVM meter shorts out the burns the circuit board, but why?
How do you prevent this from happening?
I had my red dvm meter probe on VCC +30 volts and my black meter probe on VCC -30 and it shorted out the power supply diodes and fried the board
But why?
Why would this create a short if the DVM meters negative input is connected to earth?
-30 volts VDD and + 30 volts VCC = 60 volts potential difference
Is the Bench DVM meter chassis ground connected to the meters probes?
The meter probes would have to be internally inside the bench DVM meter connected to earth or chassis ground of the DVM meter
If a circuit boards power supply earth or chassis is different then the DVM meters chassis ground or earth ground can this cause a ground loop or short when measuring from VCC to VDD rails?
When can a SHORT occur when measuring from VCC to VDD supply rails?
The grounds would have to be different how so?
30,714
What is the make and model of your DVM?
What do you mean by meter's negative input?
Is this the same as the black probe?
rc3po
Joined Feb 12, 2014
56
But why?
Hi DexterMccoy,
I'm no expert, but it sounds to me that although you think you are testing for voltage, you are actually inserting the DVM into the circuit and getting current instead. Next time, check for current and see what you get.
BillB3857
Joined Feb 28, 2009
2,570
Use a separate ohm meter and see if the negative lead of the bench DVM is connected to earth ground. (measure from the U pin of the power plug to the negative test lead) If the negative lead ties to earth ground AND the supply you are trying to measure has its zero voltage point tied to earth ground also, you are supplying a direct short to the negative 30 supply. Smoke comes out when you do that.
dubbod
Joined Oct 25, 2011
Looking at the attached circuit I do not see any +30 or -30 volt rails so I cannot see what the poster is about. If he is using a DVM acroos the power rails and it "shorts" out the board and "fries it" he has, I would suggest, set the DVM to measure current and that will cause a short circuit. I suggest he needs to be careful about his DVM setting.
BillB3857
Joined Feb 28, 2009
2,570
According to the user's manual for the Aglient 34401A, the unit can tolerate up to 500VDC between the chassis ground and the input negative lead.
Papabravo
Joined Feb 24, 2006
21,159
As has already been observed it is hard to imagine a voltage measuring device providing a low resistance path between the probes. A voltmeter (DVM) is normally in parallel with the voltage difference you are trying to measure. If it had a low resistance, the measurement would not make much sense because the current draw through would overwhelm the current in the load.
DexterMccoy
Joined Feb 19, 2014
429
What is it called when you measure the resistance from chassis ground to earth ground? or from the chassis ground or earth ground from the test fixture to the circuits chassis ground or earth ground? you're measuring the resistance from earth ground to another earth or chassis ground
This test is to make sure the oscilloscope needs to have an isolated transformer
If there is resistance between earth grounds or chassis grounds , then there will be a potential difference which will cause damage to the oscilloscope
Do you guys know what this type of test is called or how to do this test?
DexterMccoy
Joined Feb 19, 2014
429
but when do you know when an oscilloscope needs an isolation transformer for measurements , so it doesn't damage the O-scope?
The problem is that I don't know when to use an isolation transformer for a test fixture, circuit board or O-scope
It it used when there is a ground potential difference between the O-scope and what you will be measuring
BillB3857
Joined Feb 28, 2009
2,570
Most scopes have the chassis grounded to earth ground therefore the ground lead of the probe is also tied to earth ground. The isolation transformer would then best be used to power the unit under test. Be aware, however, that many isolation transformers only provide isolation to the power, ie the wire that would normally be tied to neutral is not tied to earth. The U pin on the input lead and the output socket of the isolation transformer are usually connected. Just think through the various possibilities for trouble when making the connections.
profbuxton
Joined Feb 21, 2014
421
Dexter, I find your questions rather odd. Can you give me some background as to your qualifications and current occupation so any answers may suitably tailored to suit to current knowledge. Do you actually work in a electronics environment or do you just look over someones shoulder and then ask questions. I would be very interested to know just what it is that makes you so interested in pursuing some rather (to me), inane questions.
profbuxton
Joined Feb 21, 2014
421
What is is called when you measure resistance from earth ground to chassis ground? Its called (and I will say this slowly) AN EARTH CONTINUITY TEST!!. Why do we do this?
To check EARTH CONTINUITY!!
OK now go ahead and ask why we need to do this!!
34,285
Understand that Dexter or one of his aliases will likely continue to ask variations of the same question in different ways over and over until everyone gets tired of answering. :rolleyes: Then he moves on to another question.
Status
