Shorting DC batteries...
Discussion in 'General Electronics Chat' started by SneakyShot, Oct 24, 2009.
  1. SneakyShot
    Jun 15, 2009
    6
    I was reading an instruction manual on how to set up a wind turbine generator and in the circuit diagram they had a few batteries hooked up in parallel. Could someone please explain to me why they would do this? Would this not short the batteries?
    Thank You
  2. MikeML
    Oct 2, 2009
    5,450
    1,066
    No, paralleling well-matched batteries is equivalent to just buying a bigger battery. Question? what is the difference between a 50Ah battery and a 100Ah battery? Answer, more plate area. Does it matter if the plate area comes in the same bucket or two different buckets? The caveat is "well-matched", both have to start out new good, and be fully-charged when first connected in parallel.
    What would short two batteries is to connect +- on the first to -+ on the second. Hold on to your shorts.
  3. SneakyShot
    Jun 15, 2009
    6
    Ok yea that makes much more sense. Thank you for clarifying.
