shorted pin 1 and 8 555 timer IC
Discussion in 'The Projects Forum' started by biiiboooy, Feb 28, 2012.
  1. biiiboooy
    Feb 28, 2012
    what can be the reason why pin 1 and 8 of my 555 timer ICs keep shorting when i put it in my circuit and connect the supply.
  2. nerdegutta
    Dec 15, 2009
    2,572
    807
    I suggest you post a picture of your circuit. Most likely, there is something wrong with that.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    Those are the power supply pins. There are ways of shorting the power supply elsewhere on the 555, such as pin 7.
    You could simply have a short somewhere, I agree a picture would help.
  4. eric ndungu mwangi
    Feb 28, 2012
    please post your circuit diagram you are using in your connections and also your circuit,it will really help to see the connection of other components in the circuit board.
  5. jimkeith
    Oct 26, 2011
    539
    99
    My guess is that you may have the power supply connected reverse--this will do it every time...
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    I've done that. The 555 never survives.
