It is and it isn't; depending on your definition of a short.our prof said that D and C is not short but i believe it's otherwise.
i mean 1) for short.It is and it isn't; depending on your definition of a short.
1) D and C are shorted if you consider that a short means having no resistance between 2 points.
2) D and C are not shorted if you consider that the voltage source has a total resistance (load) of greater than 0 ohms.
(The same goes for points G and F, as well as E and H)
