short in my circuit! I must be blind
Discussion in 'General Electronics Chat' started by mikey11, Mar 21, 2008.
  1. mikey11
    Mar 21, 2008
    Can anyone help me find a short in my circuit?
    I am making a timer for a local toastmasters club, I will be using a pic16f628a with a 16x2 hd44780 display.
    Three buttons and three LED's
    I have made my board using a 7805 to step down a 9v battery for testing purposes.
    when I measure between +5v and gnd I get 3.06k ohm resistance
    I can't figure out where I've gone wrong. when I connect the 9v battery I get a hot 7805, but I have removed quickly and I know 7805s are quite tolerant to silly mistakes.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    3,000 ohms to ground from a 5 volt regulator is only 1.6 milliamps. That won't make the 7805 get hot. Do you have a capacitor from the 7805 output to ground to bypass oscillations? If not, add a .1 uF ceramic as close to the output terminal (7805 pin 3) as you can place it.
  3. KMoffett
    Dec 19, 2007
    2,584
    234
    Pad at the left end of the top resistor is shorted to the top trace, or it looks like that in the image. That shorts the right and center pins of the 7805. Input to ground or output to ground, depending on orientation.
    Ken
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    KMoffett nailed it.
    The short (from the output of the 7805 to ground) is circled in red.
