Short distance radio waves
Discussion in 'Wireless & RF Design' started by MASNSN, May 20, 2012.
  1. MASNSN
    May 17, 2012
    7
    Hi experts
    I want to develop a small radio emitter and a number of receivers in order to use them in a conference room the question is what kind of radio waves should I use and if there is an open hardware that does the job I will be gratefull any advices are welcome
    Thank you
  2. MrChips
    Oct 2, 2009
    12,623
    3,451
    2-metre band FM, 144.9MHz-145.1MHz
    The FM Broadcast band is 88MHz - 108MHz.
  3. TecknoTone
    May 20, 2012
    21
    Magnetic induction loops are often used for small areas. As for suitable bands, that would depend on where in the world you are.
  4. coldpenguin
    Apr 18, 2010
    165
    9
  5. radiohead
    May 28, 2009
    474
    31
  6. Papabravo
    Feb 24, 2006
    10,338
    1,850
    You forgot to mention that operation on the 2M band, which runs from 144-148 MHz. requires a valid amateur radio license.
  7. MrChips
    Oct 2, 2009
    12,623
    3,451
    oops. I thought we were all amateurs.;)
  8. Papabravo
    Feb 24, 2006
    10,338
    1,850
    Could be, but fer sure we're not all licensed
