There is no such thing.....im thinking about making a circuit that causes electrical shorts
so how can i make this circuit to continuously cause safe electrical shorts without damaging the circuit?!
What is the relationship of current and voltage in a capacitor?even if i save the current in a capacitor then disconnect the circuit before the short occurs to prevent the damage ?!
This doesn't make sense. Your power source can efficiently deliver energy to, say, an electric motor that can drive a wheel. You could use a heater to make steam to drive an engine and your wheel.because im wondering if the power coming out the short can cause power to cause wheel motion
No wheel I've ever seen can convert electrical energy to mechanical....well i meant the voltage.. listen the thing is that im wondering if i can use the power coming out the short to cause wheel motion
Ever hear of an internal combustion engine?the other day i'v witnessed an electrical short coming out the socket and there was this small explosion so i was wondering if i can make a circuit can make purposely make spark in a cylinder to cause wheel motion .. that is the idea im thinking about .. so how can i make this happen
Electrical motor? Or are you wanting to directly apply the "short circuit" to move a wheel?but this internal combustion engine uses fuel .. i want to do the same but using electricity not fuel so it wont cause emission
but i dont want heat i want fireUsing electrical energy directly in an electric motor is far more efficient than converting that energy to heat first, as your short did, and then trying to use that heat to power a motor. Heat engines are less efficient than electric motors.
(Making the electricity in the first place and transmitting it to your house introduces big inefficiencies end-to-end, but the last bit from your wall to motor shaft-work is very efficient.)
If you just want heat, burn the coal or natural gas that would have been used to make your electricity. You'll get much higher efficiency overall.
You need to transfer the electrical energy to mechanical energy.. an electric motor does this through magnetics....yes directly apply the short circuit to move a wheel
A motor is not always "constantly fed"....yeah but what im trying to do is saving electrical energy by pulsing the voltage instead of constantly feeding the motor as in electric motoros
by Jake Hertz
by Aaron Carman
by Jake Hertz
by Jake Hertz
