Short circuit
Discussion in 'Homework Help' started by p75213, Aug 14, 2011.
  1. p75213
    May 24, 2011
    39
    I am wondering about the flow of current through the short circuit in the attached diagram. To my mind it is undefined for the following reason:
    Voltage accross the short circuit = IR. As resistance is zero then V is also 0.
    Current is V/R - 0/0. Undefined.
    Is this the case? In reality I know a short circuit does indeed have current running through it.
  2. Zazoo
    Member
    Jul 27, 2011
    114
    43
    In analyzing the lumped element model of the circuit the nodes not separated by elements are considered to be the same node for the purpose of analysis. i.e. for all intents and purposes, the left side of the 1Ω resistor is physically the same point as the positive end of the 12V source (as well as the top and bottom of the 4Ω and 12Ω.)
    In a real circuit there may be an actual wire, in which case the wire always has a non-zero resistance.
  3. victorhugo289
    Member
    Aug 24, 2010
    49
    Look, I like your circuit.
    Basically you don't have a short circuit in there, :D
    You just have a battery of 12 volts connected across a resistor of 1 ohm.
    The "short circuit" is just a wire connected to the positive side of the battery.
    Haha. (sorry)
    And the other resistors are shut down, those parallel ones (4 and 12 ohm) they have no voltage or current runnign through them at all. It's like they're not even there.
    The current through the "short circuit" is 12 amps!
    But it's not a short circuit.
  4. wmodavis
    Oct 23, 2010
    737
    150
    There is current in the loop consisting of the 12V battery, the 1 ohm resistor and the short. I =V/r=12/1=12 amps flowing through the short.
  5. steveb
    Jul 3, 2008
    2,433
    469
    Of course it's a short circuit.
    This looks like a simple model of a 12V battery with a 1 ohm source resistance driving 4 Ohm and 12 Ohm loads in parallel. The battery (realistic model of ideal source with source resistance) is shorted.
  6. MrChips
    Oct 2, 2009
    12,636
    3,455
    Just a matter of one's perspective.
