Short Circuit Shut-Down?
NM2008
Joined Feb 9, 2008
135
Could someone tell me, is there an ic for high current cut-off,
I need to set up a circuit that once a short occurs a relay would be triggered, a basic safety device.
So could someone recommend a possible ic or components?
Thanks in advance,
NM
montech
Joined Jun 5, 2008
Sure
You could set up an op amp to monitor a setpoint voltagage to drive a relay to switch on when the setpoint is being exceeded.Whats your power supply?
Externet
Joined Nov 29, 2005
2,217
Hi.
To shut down when 'high current' ... 1 Ampere, at 12 Volts
The shut down part can be either a fuse or a circuit breaker. And energize the relay when that happens ?
Try
+12V-----------fuse----------circuit---------ground
And install a 12V relay in parallel to the fuse.
Miguel
montech
Joined Jun 5, 2008
Ok 12 @ 1amp.Would you look at the following file.I short give us some ideas.This is a current foldback circuit.It will shut down the supply when
the trip voltage adjusted by R4.So I think you can see you can adapt very few parts from this to protect your circuit.You could replace the lamp with a relay,etc.Also do you have parts on hand?You can always build this circuit with a simulator to work all the "bugs" out.I like this approcah best cuz if you make a mistake there is no smoke:).One i like is "tina"
www.tina.com.free. Anyways the idea miguel has will work in a pinch:p
NM2008
Joined Feb 9, 2008
135
Thanks for the help everyone!
I never thought of using a fuse, overlooked the most simplistic idea!
There ya go!!
Anyway, thanks montech for the info on current foldback circuit.
Much appreciated!
NM
