I never sholdered a circuit before. So i checked the circuit in bread board and after everything ok i sholdered it. After finishing the job and before connecting to power and placing IC, i checked the resistor and capacitor values using multimeter. Here i found couple of mismatches.
1. 2 of the resistors(10k) showing half value. i replaced with new but it remained same.
2. some capacitors(.1u) are showing more than its value, to be precise nearly double. and some showing 1(i assume very high value).
Am i not supposed to get the original value (even though they are in a circuit) because i did not supply power??
So does it mean i have done something wrong in shouldering the correct circuit???
Is there any other better way to know whether i damaged them while sholdering??
Thanks in Advance
Note: for capacitence checking i used the multimeter
Thanks in Advance
