Shoe tossing
Discussion in 'Off-Topic' started by samjesse, Dec 26, 2009.
  1. samjesse
    Thread Starter Active Member
    Sep 14, 2008
    202
    Hi
    I consider shoe tossing as described here a bad childish behavior. I was thinking how to remove them. till I came across some reading on laser burning objects. so I thought if I can aim the laser at the thread that hangs the shoe I will be able to burn it, once it gets-week/starts to burn, the shoe will drop to the ground.
    That is the reason for my thread "laser diode" which was closed by the Super Moderator with his comments "This is not acceptable."
    thx
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    From paragraph 2 of the code of conduct:
    You must understand that you are not the only person obtaining information from these forums. Many others can read the thread. We have no control over the use of any information posted.
    Any laser with enough energy to burn a shoelace can cause a fire or blind someone.
    That is definitely not acceptable.
  3. Ron H
    Apr 14, 2005
    7,050
    657
    Beenthere, you wouldn't make a good firearms forum moderator.:D
  4. loosewire
    Apr 25, 2008
    1,584
    435
    Ron,If you took the (no) off It would be problem maybe,
    but we could smell It coming.
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    You know, if a laser pistol won't bring those shoes down...
