Shiftregister goes Haywire with load on relay
Discussion in 'General Electronics Chat' started by Raphael_DK, Jul 14, 2013.
  1. Raphael_DK
    Jul 14, 2013
    Hello.
    My first post here, so bear over with me.
    Now, my problem.
    I use a Arduino Uno with a 74HC595 Shift Register and a 5v relayboard with integrated optocouplers.
    The problem i face, is that as soon as there is load on the relay, the shift register goes haywire.
    I'm aware of that it's caused by noise, but i strugle to figure out how to wire the relay / shift register to remove that noise.
    I found following threads with solutions, but i find the schematics confusing:
    http://forum.allaboutcircuits.com/showthread.php?t=73735
    http://hstech.ro/HC595/595.html
    Right now the shift register is wired directly to the arduino and the relay. No rectifier, resistor or capacitor is mounted anywhere.
    My questions is:
    How should i wire it "properly" to remove all the noise / problems I'm facing.
    I know this maybe a "simple" problem to solve, but i just can't see the solution. Maybe I'm stupid? hehe..
    Thanks in advance :)
  2. MrChips
    Oct 2, 2009
    12,652
    3,460
    Well get a darn 0.1μF capacitor across Vcc and GND of the 74HC595 plus a 10μF cap across the power supply.
    Add a 1N4001 diode across the relay.
    ErnieM and Raphael_DK like this.
  3. Raphael_DK
    Jul 14, 2013
    Thanks for the very fast answer !
    I've got both
    0.1uF 250V 104J CBB Metallized Film Capacitor
    and
    1A 1000V Silicon Bridge/Rectifier Diode 1N4007
    But i do not have a 10µf cap, is there anything else i could use instead ?
  4. absf
    Dec 29, 2010
    1,493
    374
    Is you load connected to AC mains or a higher DC voltage higher than 5V?
    Allen
  5. Raphael_DK
    Jul 14, 2013
    My relay is connected to the 230v AC mains.
    I still experience some problems with the solution above. Maybe because i don't have and use the 10μF cap across the power supply. ?
