Shift Registers
Discussion in 'Homework Help' started by full, Sep 15, 2014.
  1. full
    May 3, 2014
    225
    Hello everyone,
    I do this problem on Shift Registers (SISO)....
    I do truth table for shift register, but I think there are problem in waveform in
    {Q0''FF0'' = I choose Data in "1" for start and complete same the line }
    in {Q1 "FF1" = I choose data in "0" in clk "1" use "0" because"shift "}
    in{Q2 "FF2" = I choose data in "1" in clk "1" "2" use "1" because"shift "} ......... .
    I do waveform from Q0 to Q5 because there isn't space :cool:
    what different between SISO and SIPO in sketch truth table and waveform?
    thanks a lot,
    sorry for me poor English ....
  2. tshuck
    Oct 18, 2012
    3,531
    675
    A SIPO shift register has outputs corresponding to the output states of the constituent flip-flops, where a SISO has only the last flip-flop's output as an overall output.
  3. full
    May 3, 2014
    225
    thanks sir, I think my truth table and waveform wrong?
  4. full
    May 3, 2014
    225
    I do another problem ........
    I think this is true :)
    the FF11 is Qout?
    thanks,
      File size:
      2.3 MB
      30
      File size:
      23.8 KB
      27
  5. LDC3
    Apr 27, 2013
    920
    160
    These tables are correct, but I don't understand what you did on the rest of the page.
  6. full
    May 3, 2014
    225
  7. full
    May 3, 2014
    225
  8. tshuck
    Oct 18, 2012
    3,531
    675
    Looks correct at first glance, though it is typical to label Q0 as the LSB... You should get into the habit of labeling MSB/LSB so that it is immediately clear to someone else reading your work.
  9. MrCarlos
    Jan 2, 2010
    400
    134
    Hello full
    Speaking of your first post in this thread:
    Analyzing the content of the image that you enclose in your original message I can see that the small box, I think is a 12 BIT’s shift register (STG 12).
    On the graph, in the lower part of your drawing, I count 13 changes from 0 to 1, I mean 13 clock pulses.
    The registers were preloaded with HEX number A78. (101001111000 binary, 12 BIT's).
    Therefore, the registers in the shift register will have, after the 13 clock pulses, the DataOut -1. Its LSB.
    Data Out = HEX 1DDA (1110111011010 Binary, 13 BIT's.). After defined by synchrony Clock and Data In.
    But if you are considering that only 12 clock pulses are applied to the shift register, then the registers in the shift register will contain the Data In you find based on the graph at the original image that you enclose.
    The graph is regarded as a ramp in the form as copied.
    I straightened and get the Data Out as they look in the picture I attached.
    You've asked:
    The sketch
    The definition can be defined by the acronym.
    SISO Serial In Serial Out.
    SIPO Serial In Parallel Out.
    This surely you knew.
    SISO, Data In and Out, BIT to BIT one after another.
    SIPO, Data In BIT to BIT one after another; and Out all BIT’s at the same time. Of course, after all BIT’s were loaded. Or could present in the displacement mode (Shift).
    The truth table and waveform.
    All these data are given at their own data sheets. 2 of which I enclose.
    You can find more information at this link asking for SISO, SIPO, Etc. + Shift register
    http://www.alldatasheet.com/
    full likes this.
  10. full
    May 3, 2014
    225
    Thanks a lot sir, your nice support
  11. full
    May 3, 2014
    225
    what different between MSB and LSB?
    in waveform and truth table......
    thanks a lot,
  12. MrCarlos
    Jan 2, 2010
    400
    134
    Hello full
    Well, what is different between MSB and LSB is the same as decimal numbers.
    for example, in the decimal number: 505, 5 to your left (LSB) are just five, while 5 to your right (MSB) are Five Hundred.
    Then binary number 101, 1 your left (LSB) is only one, while your right 1 (MSB) is eight.
    In this binary number; 101011 blue is the LSB while red is the MSB.
    You Say:
    I would have to develop(To Do) a circuit to show that.
  13. full
    May 3, 2014
    225
    Thank you sir for help me , now I understand what different between LSB and MSB.:)
  14. full
    May 3, 2014
    225
  15. full
    May 3, 2014
    225
  16. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
    full likes this.
