shift register
wael_73
Joined Nov 13, 2008
please i need to make circuit using microcontroller pic
this circuit derive voltage to different 32 channels but in serial manner like shift rgesiter .
i.e the first channel is go high (1) then go low(0) , some delay and the second channel go high then go low and so on until we reach 32 then we start again from channel 1 .
would you suggest which microcontroller i will use , i think about pic 16f84 but it has 9 port only ,how can i extend this ports ?
RiJoRI
Joined Aug 15, 2007
536
Look into serial to parallel converters. Using 4 converters will give you 32 lines. The converters will share Clock, Data, and Output Enable lines, and have individual Chip Select lines.
--Rich
thatoneguy
Joined Feb 19, 2009
6,359
You would use the uC for the clock, data, and enable lines, which would allow you to vary which lines are on when, and for how long. How critical is the timing?
Tahmid
Joined Jul 2, 2008
343
Hi Wael_73,
This is an easy circuit. You can use 2 nos. of 1:16 multiplexers(74150) and a pic micro controller.
You can very well use pic16f84/16f84A and this Pic does not have 9 ports, rather it has 2 Ports(A and B) and 13 input/outputs. Port A having 5(pin17,18,1,2,3) input/outputs and Port B is having 8 input/output(pin6,7,8,9,10,11,12,13).
