Shift register
Discussion in 'General Electronics Chat' started by gorgondrak, Jan 7, 2015.
  1. gorgondrak
    Nov 17, 2014
    61
  2. ericgibbs
    Jan 29, 2010
    2,604
    396
    hi,
    Do you mean pin#1 , which is /CS.?
    If so, its Low to Select the IC.
    E
    Which pin number is it on the 24pin DIL package.?
  3. gorgondrak
    Nov 17, 2014
    61
    So pulling it high will disable the clock, deselecting the IC?
  4. ericgibbs
    Jan 29, 2010
    2,604
    396
    Setting /CS High will disable the IC.
    Sometimes more than one Shift Reg can share the same Clock and Data lines, so the /CS is used to select the required S/R.
