Shift register loop
Discussion in 'General Electronics Chat' started by GopherT, Oct 15, 2015.
  1. GopherT
    Thread Starter AAC Fanatic!
    Nov 23, 2012
    6,297
    4,019
    I have not worked with shift registers in a while and when I did, it was fairly straightforward in to out. Now I have a question for a chaser project, is it possible to put two or more 'serial in/parallel out' shift registers together head-tail in a loop to pass the bits in a circle?
    I am sure it can be done with a buffer flip-flop bit at the end of a head/tail series of shift registers (e.g. 'carry bit' for a rrf/rlf command) but can it be done only as a loop?
  2. kubeek
    Sep 20, 2005
    4,686
    805
    Yes you can, but you will need some glue logic to let you feed the pattern inside in the first place and then switch to circulation.
    GopherT likes this.
  3. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,679
    1,295
    An alternative to kubeek's suggestion is a more complex shift register part that can be parallel loaded with the pattern. This is sometimes called a universal shift register because it is parallel in and out and serial in and out. 74195.
    ak
    GopherT likes this.
  4. GopherT
    Nov 23, 2012
    6,297
    4,019
    Yes, I already have the glue logic with a feed-in switch, a toggle for the logic level and a push button clock to feed in the first pattern. Then I'll flip the feed-in switch back to form the loop, start the real clock and away I'll go.
    Thanks! Just wanted to make sure I wasn't missing out on something if they were cascading like dominos on each clock tick or if they all happen in unison. Cheers.
  5. cmartinez
    Jan 17, 2007
    3,696
    2,748
    Gopher, do you have a digital logic simulator? If you don't, then I suggest you take a look at digital works. It comes with some predefined logic chips and all.
  6. GopherT
    Nov 23, 2012
    6,297
    4,019
    Thanks, I already have one but it did not include a shift register for some reason. Also, some little things do not simulate reality very well.
