Shift register delay
Discussion in 'Homework Help' started by zulfi100, May 5, 2013.
  1. zulfi100
    Jun 7, 2012
    320
    Kindly guide me with the following:
    I dont know about the delay.
    Zulfi.
  2. crutschow
    Mar 14, 2008
    13,482
    3,370
    It's asking how long it would take a particular pulse to go from the input and appear at the output of the n-stage shift-register, given a clock period of T.
    Do you know how a shift-register works? If so, then the above calculation is quite simple.
  3. WBahn
    Mar 31, 2012
    18,085
    4,917
    Draw the timing diagram for a pulse (or a step) applied to the input of a D-type FF and then produce the output waveform of the DFF's Q output. Now send this into a second DFF and produce the output of that DFF's Q output. This is a 2-stage shift register. Add a third stage if needed, but you should see the pattern by this point.
  4. zulfi100
    Jun 7, 2012
    320
    Thanks for your reply.
    Okay i would try this . It would help in my understanding. But my drawing is not good.
    Zulfi.
  5. WBahn
    Mar 31, 2012
    18,085
    4,917
    We don't require good drawings, just drawings that are capable of conveying the information reasonably well.
