Shielded wire
Discussion in 'General Electronics Chat' started by Dritech, Nov 14, 2013.
  1. Dritech
    Sep 21, 2011
    756
    5
    I am going to use shielded wires for the power lines to a DC motor. Do I connect the shield with the power supply output ground or with the ground from the mains (input of the transformer)?
    Also, will twisting the wires help to reduce any noise?
    Thanks in advance.
  2. t06afre
    May 11, 2009
    5,939
    1,222
    DC motors are quite robust then it comes to noise, but create a lot of noise. The problem may be that noise from the DC motor affect other parts in the system. So it may be wise to pay attention to such thing as your grounding regime. And shielding of the control units.
  3. Dritech
    Sep 21, 2011
    756
    5
    Thanks for the reply. Shell I connect the shielding with the supply ground or with the mains earthing?
  4. t06afre
    May 11, 2009
    5,939
    1,222
  5. MikeML
    Oct 2, 2009
    5,451
    1,066
    Shielding, by itself, will rarely help if the underlying problem is common-mode noise due to ground-loops. You should explain what is happening and how your system is wired.
  6. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
