sharp IR sensor
Discussion in 'The Projects Forum' started by lina889, Oct 20, 2010.
  1. lina889
    Oct 4, 2010
    11
    is it possible use sharp IR sensor to detect the car if it in the garage or not
    if it on the garage the led will be
    if not the led will off ?????
    all that using pic16f877a
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You will need an IR source to be detected by the sensor. It is simply an on/off function. What might be the purpose of the PIC?
  3. lina889
    Oct 4, 2010
    11
    am working om automatic car parking system in need a sensor to detect if there is a car in the park or not if there a car the led will be on and if not the led will be off
    what is the kind of sharp IR sensor can i use and how to use it ???
  4. marshallf3
    Jul 26, 2010
    2,358
    201
    Model cars or real ones? Outside, inside?
  5. lina889
    Oct 4, 2010
    11
    no model car the garage in a building
  6. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Can't make sense of that, it's missing some important words.
  7. windoze killa
    Feb 23, 2006
    605
    24
    Firstly you need to supply more information. The more detailed your question the more detailed the responses will be.
    Are you trying to detect if a car is parked within a car space in a multi car garage (shopping centre or apartment complex) or a single car at home? Either way I would place an IR LED on the floor and an IR sensor in the ceiling. when a car parks over the LED it will break the beam and deactivate the sensor.
    Have a think about that and see what you can come up with. When you have some ideas we maybe able to help more.
  8. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    That placement might be troublesome with dirt.
  9. windoze killa
    Feb 23, 2006
    605
    24
    Well I didn't say the maintenance side of it would be easy. ;):D
    Anyway I was just throwing out some ideas for him to think about. He has to do all the hard work.
  10. marshallf3
    Jul 26, 2010
    2,358
    201
    If the parking space is dirt simply bury a large diameter coil of wire to act as a metal detector.
  11. lina889
    Oct 4, 2010
    11
    thxx for your replay am to trying to detect if a car is parked within a car space in a multi car garage in shopping center in each garage i need a sensor to detect if there is a car or not which the perfect kind of IR sharp sensor i perfect to detect that ???
    and the the most distance it can detect in ????
  12. windoze killa
    Feb 23, 2006
    605
    24
    I have had another idea for you. Mount ultrasonic transducers in the roof of the garage pointing down to the car space. You can then measure the time it takes for the signal to bounce back from the ground. When a car is parked there the distance will be less and the time will be shorter. Just another option because as marshall said the IR sensors may get dirty.
  13. lina889
    Oct 4, 2010
    11
    ultrasonic is the first one i think a bout it but am working on graduation project and i need more then 10 sensor of it but thats to expensive i need any kind of sensor to detect the object and connect it to led thats all and something not expensive
  14. marshallf3
    Jul 26, 2010
    2,358
    201
    10 spaces and something like 1 LED to light up if there's a car in that spot?
    Since this is a project I guess you can't assume dirt as the parking surface, but can we assume a roof over it?
    I like the ultrasonic idea but there again it would be dirt and water on the floor and the necessity of a roof overhead being the only way to avoid that.
    I really think I'd consider my idea of buried sensor loops identical to how they trip most stop lights at intersections. It's practical for a parking garage to get a "slot cutter" that would allow the wires to be buried in the parking surface and all run to a central location.
    In essence the way these circuits work is by utilizing the loop of wire as the inductor in a simple colpitts oscillator. When a car parks over the loop the metal of the car increases the effective inductance of the loop thus inducing a fairly decent change in the oscillator's frequency. Since the frequency would go lower you should be able to use a simple 555 missing pulse detector to sense the difference and trigger the LED on.
  15. mbohuntr
    Apr 6, 2009
    413
    32
    Oh gee thanks for that new knowledge (Oscillators and inductance), now I have more stuff to research on the internet... (Will this never end???, my brain is sooo tired...):rolleyes:
  16. lina889
    Oct 4, 2010
    11
    the led is for each garage in each slot...
    i think IR transmitter receiver is a good idea i want to but them Against each other in each garage when the car is in between the transmitter and he receiver the led will on other wise the led will off
    is that a good ????
