Hello everyone. I find myself requiring a bit of your assistance:
How would I compose a plc program to activate outputs at different distances? For simplicity sake:
This sensor senses from 10-80cm...Therefore, at 10 cm and 50 cm I would like to activate an output.
Here is the sensors data sheet from manufacturer: http://www.sharpsma.com/webfm_send/1489
Project #1:
The project given to me is to use this sensor to lift a piece of steel with an electromagnet at these heights and activate a light. Can I use a current transformer to sense when the electromagnet is activated? Is a 120Vac winch motor a good means to lift steel with electromagnet? If I wanted to get "fancy", how would I use some sort of display to indicate heights?
Project #2:
How would I use a touch screen HMI to just input any height I want to lift piece of steel with electromagnet while indicating present height? What cheap priced hmi compatible with hardware can I use for both projects?
Your help is much appreciated!!!!!
Project #1:
Project #2:
