Shannons Theorem Expansion Problem
Discussion in 'Homework Help' started by Shamieh, Mar 14, 2014.
  1. Shamieh
    Oct 24, 2013
    36
    Can someone check my work please?
    Problem: Consider f defined below. Apply Shannon's expansion theorem (also given below) with respect to input y as if you were implementing this function using a 2:1 MUX. Find the minimum equations for f(w,x,0,z) and f(w,x,1,z).
    Shannons Expansion Theorem
    f(w_1, w_2,.....,w_n) = ~w_1 * f(0,w_2,....,w_n) + w_1 * f(1,w_2,....,w_n)
    The function to be expanded: f(w,x,y,z) = wy + ~w~x~y + ~w~y~z + wy~z
    Here is what I got for my solution.
    ~y(~w~x + ~w~z) + y(w + w~z)
  2. panic mode
    Oct 10, 2011
    1,328
    305
    not sure i understand your notation but assuming tilda means next char is inverted then:
    therefore:
    f(w,x,0,z) = w0 + ~w~x~0 + ~w~0~z + w0~z
    f(w,x,0,z) = 0 + ~w~x + ~w~z + 0
    f(w,x,0,z) = ~w~x + ~w~z
    f(w,x,1,z) = w*1 + ~w~x~1 + ~w~1~z + w1~z
    f(w,x,1,z) = w + ~w~x*0 + ~w*0~z + w~z
    f(w,x,1,z) = w + 0 +0 + w~z
    f(w,x,1,z) = w +w~z
    Shamieh likes this.
