Shaft Rotation Direction Change Sensor Needed
Discussion in 'General Electronics Chat' started by crestor, Jul 7, 2009.
  1. crestor
    Jul 7, 2009
    I need a sensor to detect a change of direction in a rotating shaft. When the sensor detects the sudden change in direction it would trigger action of an electromagnet. The sensor would monitor either the shaft or a disk attached. A 12 volt dc power source would be used in the circuity.
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    It sounds like you are trying to make a electromagnetic brake. You can tell direction of something like a winch drum very simply using one magnet on the drum and two Hall sensors. There are some limitations/restrictions to that method, as it is based on measuring a simple time interval. However, if you think it might be applicable to your problem, let us know here, and I will post more detail.
    John
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Can you simply monitor applied voltage to the motor?
  4. Bernard
    Aug 7, 2008
    4,242
    417
    Read: AAC, Vol., IV, Digital, Ch. 11, Counters, Synchronous. last paragraph for inf. on shaft encoders.If the code disc is half black, it will take 1/2 turn to detect direction change, to detect sooner, need more segments.
