Is this another Scam?
https://www.indiegogo.com/projects/asap-dash-world-s-fastest-pocket-sized-charger#/story
They claim to be able to fully charge a 5000mAh battery in 15 mins using a 50 watts charger???
Is that even possible? 5000mAh @5 volts = 25 Wh battery.
Assuming a 100% conversion efficiency and a constant charge rate(batteries don't charge at a constant charge rate the last 20% actually takes a lot longer) a 50 watt charger would take 30 mins at the least to charge, right?
