Could you explain more abt this? You can use serial port. There are a lot of articles/example out there that use serial port to control some external hardware. Since you're using VB6, i recommend you to use mscomm32.ocx. This object allow you to access your PC serial port. You also need MCU or any logic circuitry to decode and drive the 7segments.Dear All
I want to make 4 digit seven segment and control it with vb6. Could anyone advise me, where do i can read the knowledge or discussion about it.
Best Regards
Kholid
by Jake Hertz
by Aaron Carman
by Jake Hertz
by Aaron Carman
