Setup to test a filter
Discussion in 'General Electronics Chat' started by atferrari, Apr 5, 2014.
  1. atferrari
    Thread Starter AAC Fanatic!
    Jan 6, 2004
    2,668
    784
    I have never done this before.
    Today I started to test the state variable filter in the attached circuit.
    My setup is just a (brand new) function generator sweeping from 30 Hz up to 30 KHz, 1 V pk-pk - 0 offset. Output impedance set to 50 ohms and signal applied to R8 which not yet connected to the preamp.
    Soon I realized that I needed to trigger the scope (generator's 2nd channel, delivering pulse with the same period of the sweeping).
    Basically I get a response that barely looks what I could expect for HP, BP and LP (albeit irregular and asymetric) but I cannot find anything that I could call a notch.
    Op amps polarization checks as +4,4V, in case you ask.
    Eventually I could take some pictures tomorrow.
    My questions: am I doing right?
    How to measure fc? I suspect there is an obvious way but I cannot think of any right now. I have no markers available.
    Comments and suggestions will be aprreciated.
  2. tshuck
    Oct 18, 2012
    3,531
    675
    If you pass white noise through the filter and observe the output in the frequency domain, you can see the filter response easily.
    atferrari likes this.
  3. crutschow
    Mar 14, 2008
    13,503
    3,376
    Post a picture of the oscilloscope sweep.
  4. #12
    Nov 30, 2010
    16,704
    7,354
    Use the signal generator to drive the horizontal sweep at a logarithmic rate, if it has that ability. Mine does, and I built it from a kit about 40 years ago.
  5. atferrari
    Jan 6, 2004
    2,668
    784
    Hola crut
    After a long time trying, I learnt that my DSO has a strange way of changing settings, even if I do not use the autoset mode.
    The circuit is assembled in a very cramped perfboard. Maybe there is something wrong that I am not seeing.
    This morning I assembled the same circuit in a protoboard :eek:, brought back in service my old and friendly analog scope and enabled the generator's sync output.
    The notch is there, as we use to say, "big as a house" together with other expected outputs.
    Being my first time with this, I feel happy. :) :p
    Thanks for replying.
  6. atferrari
    Jan 6, 2004
    2,668
    784
    Now that I have it working, have to see how. Is it just using the FFT function?
  7. atferrari
    Jan 6, 2004
    2,668
    784
    Yes, logarithmic sweep.
    #12 likes this.
  8. tshuck
    Oct 18, 2012
    3,531
    675
    ...That'll do it...
