Setting values for LTspice digital device models?
Discussion in 'Digital Circuit Design' started by Alec_t, Jul 2, 2016.
  1. Alec_t
    Thread Starter AAC Fanatic!
    Sep 17, 2013
    5,980
    1,138
    I would like to set a Vhigh or Vt value for a buffer or other model in the LTspice 'Digital' folder, so that the value is ratiometric with the supply voltage Vdd, e.g. Vt=Vdd/2.
    If I know Vdd in advance it is simple to set Vt=2.5 (say). But what if Vdd is unknown or varying? How is Vt set then?
  2. crutschow
    Mar 14, 2008
    13,521
    3,388
    Are you referring to the generic digital models in LTspice?
  3. eetech00
    Jun 8, 2013
    685
    118
    Hi
    The digital "A" device parameters only accept values that are evaluated before a simulation run.
    but you can use a B device to compute a value so it scales to the value that is set for the A device parameter.
    For example, say your digital device should support an input range of 3-15 volts. You could leave Vhigh set to its default of 1v, then configure a resistor as an input pin to ground, label the input pin "in". Then use a BV device with its output connected to the input of the digital device. The value of the BV device would then be set to V=if(V(in)>3&V(in)<15,1,0).
    Hope that makes sense.
  4. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Yes.
    Perfect sense. Thanks. I'll give that a go. I had a feeling the values had to be determined before the sim run, but was hoping there was some trick to get round that limitation.
  5. Bordodynov
    May 20, 2015
    673
    194
    See
