Setting up the PICKit 3 Lesson 01
Discussion in 'Embedded Systems and Microcontrollers' started by LutherBaker, Oct 5, 2012.
  1. LutherBaker
    Sep 24, 2012
    13
    I just purchased the PICKit 3 ... I already had MPLAB IDE installed and the Lesson PDF asks me to install MPLAB C Compiler for the PIC18 v3.13 - so I donwloaded and installed the latest ... mplablc18 v3.43 (lite version).
    Part of lesson 1 navigates to C:\MCC18\lkr to include some linker files - but I don't have that directory. I am supposed to include the following files ...
    • 18f45k20.lkr
    • 18f45k20_e.lkr
    • 18f45k20i.lkr
    • 18f45k20i_e.lkr
    I did a global search in my system and I found two places that have
    18f45k20_g.lkr
    Here: C:\Program Files (x86)\Microchip\MPASM Suite\LKR
    and here: C:\Program Files (x86)\Microchip\mplabc18\v3.43\bin\LKR
    Did I install the wrong program? How do I find the files the lesson wants to use?
    Thanks,
    -Luther
  2. t06afre
    May 11, 2009
    5,939
    1,222
    Use the lkr file "C:\Program Files (x86)\Microchip\mplabc18\v3.43\bin\LKR" and you should be fine
  3. LutherBaker
    Sep 24, 2012
    13
    Thanks.
    I also learned that, since C18 v3.40, no linker files are required :)
    -Luther
  4. LutherBaker
    Sep 24, 2012
    13
    Just a recap:
    Running Windows 7, the MPLAB 8.* software can't seem to get past this stage of trying to recognize the PICKit 3:
    Connecting to MPLAB PICkit 3...
    Firmware Suite Version.....00.00.00
    Firmware type..............Unknown Firmware Type
    Downloading Firmware...
    Downloading RS...
    RS download complete
    At this point, the PC IDE just freezes. It flashes that it is connecting in the bottom left corner of the IDE. A progress bar keeps filling up and starting over. 10 minutes of nothing. So I shut it down and reset the PICKKit3 (holding down its button while giving it power.
    After a bit of deliberation, I download MPLAB X and try it. No luck. This time, the whole app just shuts down after the "RS download complete" line.
    I wondered if it was my PC ... so I installed MPLAB X and the compiler on my MAC ...
    Downloading RS...
    Downloading AP...
    AP download complete
    Firmware Suite Version.....01.28.07
    Firmware type..............PIC18F
    Target device was not found. You must connect to a target device to use PICkit 3.
    Ok - so after getting this message (I've got two PICKit 3 Debug Express kits) I plug in the other Debug Express target card. No luck. Same error. Since I'm farther along now, I decide to pop the PICKit 3 back into the PC and see what happens.
    And great, the IDE works much better (doesn't attempt to download or install firmware) but it reaches the exact same final error: Target Device was not found.
    I finally thought about "power" ... and turned that on in MPLAB ...
    and it worked. I can see the moving LEDs on the card!
