Setting up Analog for Thermometer Project using PIC18F4550
Discussion in 'Embedded Systems and Microcontrollers' started by corsair, Mar 26, 2010.
  1. corsair
    Mar 6, 2010
    51
    Hi guys,
    For my project I am building a mini-weather station, and a part of it includes using a thermal-resistance transducer and a PIC18F4550. For the moment, I do not have the thermometer, but my professor said that I can use a 10k Ohm potentiometer to simulate/calibrate it.
    I asked my professor to help me get started, and this is what he said:
    So, after having done this, I'm going to you guys for help. :)
    Right now, I have a 10k Ohm potentiometer hooked up to AN0, VDD, and GND. In addition, I have a 7-segment display so that I can see the temperature.
    I am not sure what I am doing wrong, this is what I have:
    Code ( (Unknown Language)):
    1. temp:
    2.     call    temp_inits
    3.     bsf    ADCON0,1,0    ; Start the Conversion
    4. temp2    btfsc    ADCON0,1,0    ; Wait for AD Conversion to Complete
    5.     bra    temp2
    6.
    7.     movf    ADRESH,0,0
    8.     dispW    digit1        ; Displays contents of W(in hex)
    9.     movf    ADRESL,0,0
    10.     dispW    digit2
    11.     return
    12.
    13. temp_inits:
    14.     movlw    0x1        ; Select AN0 and ADON = 1
    15.     movwf    ADCON0
    16.     movlw    0x0        ; Enable Analog Input from AN0
    17.     movwf    ADCON1
    18.     ; ***** this parts pretty confusing for me
    19.     movlw    0xfb        ; 20Tad, Frc (found ex and used same values)
    20.     movwf    ADCON2
    21.     return
    Anyways, that's my attempt at this temperature probe. Thanks in advance for the help! :)
  2. Tahmid
    Jul 2, 2008
    344
    27
    Try this instead:
    1. temp
    2.     call   temp_inits
    4.
    5. temp2
    6.     btfsc  ADCON0,1,0    ; Wait for AD Conversion to Complete
    7.     bra    temp2
    8.
    9.     movf    ADRESH,w
    10.     movwf   digit1        ; Displays contents of W(in hex)
    11.     movf    ADRESL,w
    12.     movwf   digit2
    13.     return
    14.
    15. temp_inits
    16.     movlw    0x1        ; Select AN0 and ADON = 1
    17.     movwf    ADCON0
    18.     movlw    0x0        ; Enable Analog Input from AN0, All ADC channels are analog
    19.     movwf    ADCON1
    20.
    21.     movlw    0x3E       ; 20TAD, FOSC/64
    22.     movwf    ADCON2
    23.     return
    Just wait for some time, if you need help understanding the code, I will try to explain it to you.
    Hope this helps.
    Tahmid.
    corsair likes this.
