Hi Everyone,
I'm trying to set up an LT3478 current source. The output i'm looking for is between 5 and 25 Volts at 3.5Amps.
The alternative (because i don't know how i would deal with 20Amps@5V input via PCB) would use a 12V supply and go from 12V to 25V @3.5amps.
I've made a couple attempts to set it up using LTSpice, but i can't seem to get a boost factor of more than 2 out of the IC. Can anybody shed some light on what i'm missing here?
In the example LT Spice circuit I've attached, I have set the sense resistor so the output should be 3Amps (0.035 Ohm), however my output never goes past 2.04Amps.If I increase the Input voltage from 12V to 18V, it is suddenly able to output the 3 Amps i'm expecting. I couldn't find this input voltage limitation in the datasheet.
Thanks in advance for any help/advice!
