setting digital I/O, pic16f690, using ccs pcm
Blasterdito
Joined Jul 9, 2008
5
Huy guys (and girls)
I have two questions
1.
I'm trying to make pic16f690 recive bytes on pin 19 RAO and send bytes on pin 10 RB7,
I have red that I need to make pins digital and also define them as in or out pins, If I'm not mistaking I need to put "set_trisx(...) somewhere?
2. How do I set the internal oscillator
I'm thinking if this is correct, and does this mean that I don't need any external xrstal?
Rich (BB code):
#FUSE INTRC and
#Delay (clock=...)
but I don't know if it's correct.
Here is my code
Rich (BB code):
#include <16F690.h>
#fuses NOWDT,HS,NOPUT,NOPROTECT
#use delay(clock=8000000)
#use rs232(baud=2400,parity=N,xmit=PIN_B7,rcv=PIN_B5,bits=9)
void clockwait(void);
void main()
   unsigned char byt;   // Holds each byte received
   unsigned char t;     // Variable t declaration
   setup_counters(RTCC_INTERNAL,RTCC_DIV_1);
   while(1)         // Loop forever...
      byt=0;         // Starting a new data frame
      clockwait();      // Ignore start bit
      for(t=0;t<8;t++)      // Grab eight bits of data...
         clockwait();
            byt|=input(PIN_A0)<<t;
      clockwait();         // Ignore parity bit
      clockwait();      // Ignore stop bit
      putc(byt);         // Send byte to the transmitter
   }            // ... rinse and repeat :)
   // Waits for the next clock cycle...
      while(!input(PIN_A1));   // Wait for clock to go HI
      while(input(PIN_A1));   // Wait for clock to go LO
I've bin trying to figure this out for 3 days now, any help would be extremly appriciated.
:confused:
Regards
