Setting bits based on a count?
Discussion in 'Embedded Systems and Microcontrollers' started by spinnaker, Mar 29, 2013.
  1. spinnaker
    Thread Starter AAC Fanatic!
    Oct 29, 2009
    5,063
    1,160
    For some reason I can't figure this one out.
    Say I have a for loop
    Code ( (Unknown Language)):
    1.
    2. for (int i=0; i<=3; i++)
    3. {
    4.      setBits(i);
    5.
    6. }
    7.
    Say my SFR has a value of 0b11000100
    How would I set the value of the 4 and 5th bits to the value of i?
  2. ke5nnt
    Mar 1, 2009
    384
    15
    You are wanting to change just bits 4 and 5 of the SFR to equal i every time it increments? So your bit sequence would look like:
    11000100
    11010100
    11100100
    Is that correct?
  3. ErnieM
    Apr 24, 2011
    7,434
    1,625
    Make a hole, slip in the bits:
    SFR = (SFR & 0b11001111) | (i << 4);
  4. spinnaker
    Oct 29, 2009
    5,063
    1,160
    Ah so I clear those bits first then set them?
  5. MrChips
    Oct 2, 2009
    12,623
    3,451
    Take i and shift it left by 4 bits
    (i << 4)
    Take SFR and mask bits 4 and 5
    (SFR & 0xCF)
    then OR the shifted bits
    (SFR & 0xCF) | (i << 4)
    Edit: ErnieM beat me to it!
  6. THE_RB
    Feb 11, 2008
    5,435
    1,305
    The smallest and fastest compiled code may be from using bit tests;
    sfr.F4 = 0;
    if(i.F0) sfr.F4 = 1;
    sfr.F5 = 0;
    if(i.F1) sfr.F5 = 1;
    (If your C compiler is one of those poor ones that doesn't allow bit testing/setting then you may not have that option.)
  7. spinnaker
    Oct 29, 2009
    5,063
    1,160
    This is basically what I do now.
  8. Markd77
    Sep 7, 2009
    2,803
    594
    If the compiler optimises i<<4 as the swapf instruction then that would be pretty fast too.
