set_power_pwm_override...help!!!
Discussion in 'Embedded Systems and Microcontrollers' started by ayu_ayfa, Apr 29, 2012.
  1. ayu_ayfa
    Sep 26, 2011
    14
    how to determine the condition for this function currently i am using this coding
    case 0:{
    set_power_pwm_override(1,true,0);
    set_power_pwm_override(0,false,1);
    set_power_pwm_override(2,true,0);
    set_power_pwm_override(3,false,1);
    set_power_pwm_override(5,true,0);
    set_power_pwm_override(4,false,1);
    break;
    case 1:{
    set_power_pwm_override(0,true,0);
    set_power_pwm_override(1,false,1);
    set_power_pwm_override(3,true,0);
    set_power_pwm_override(2,false,1);
    set_power_pwm_override(4,true,0);
    set_power_pwm_override(5,false,1);
    break;
    in order to get the output as attached(untitled2)..but the signal produced from the coding above attached(untitled)..
    so now, i have no idea how to adjust the coding above especially about the true/false and also the condition 1/0....i do not know how to make the double phase shift..from my result,it only show one phase shift...
    anyone pls help me..:confused:
