Set screws keep coming loose on stepper motor coupler.
Discussion in 'Off-Topic' started by spinnaker, Jan 31, 2016.
  1. spinnaker
    Thread Starter AAC Fanatic!
    Oct 29, 2009
    5,062
    1,159
    If you do not already know, I purchased one of those cheap Chinese CNC engravers ro experiment with engraving PCBs.
    On one of the stepper motors, the set screw in the coupler from motor ro shaft keeps coming loose. I need to tighten it every few runs. I thought about some locktite to fix it but I am worried I won't be able to get the screw back out if need be. The screws are pretty tiny.
    Any ideas on the best way to fix this?
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    Loctite is color coded. There is a very firm, green version that requires heat to remove. I suspect any of the red versions will work for you. "Permanent" is only relative and depends on the fastener size. I would have no problem using a red permanent version in your application. Worse comes to worse, you can use heat to remove the set screw.
    John
    Hypatia's Protege likes this.
  3. tracecom
    Apr 16, 2010
    3,878
    1,396
    You might try some dabbing some fingernail polish (color optional) on the screw after it's seated.
  4. #12
    Nov 30, 2010
    16,655
    7,293
    Blue is the soft thread locker.
    I used some red on a guitar jack and I had to use a grinder to cut it off.:mad:
  5. Lestraveled
    May 19, 2014
    1,957
    1,217
    The set screw might be out of tolerance. (Chinese grade). You might try replacing it.
    As far as Loctite, I would use Blue.
  6. jpanhalt
    Jan 18, 2008
    5,699
    909
    As an additional aid, if the shaft is round, you might consider filing a flat on it or drilling an indent where the screw sets into it.
    John
    shortbus and #12 like this.
  7. spinnaker
    Oct 29, 2009
    5,062
    1,159
    OK locktite or nail polish?
    I thought about nail polish put where the screw sits it might be a little difficult to scrap off. Though I suppose I can get a screw driver in there.
  8. spinnaker
    Oct 29, 2009
    5,062
    1,159
    Was going to ask that too. It is round.
    Another thought I had was to put a dab of nail polish on the shaft where I intend to put the set screws. Let it dry first of course.
  9. #12
    Nov 30, 2010
    16,655
    7,293
    Too brittle. No grab.
    It works for an outside coat, or a thread lock, but it won't work for a point controller.
    It scrapes off easy because it is too brittle.
  10. tracecom
    Apr 16, 2010
    3,878
    1,396
    Acetone on a Q-tip.
    spinnaker likes this.
  11. spinnaker
    Oct 29, 2009
    5,062
    1,159
    So would you suggest filing the shaft a bit then?
  12. spinnaker
    Oct 29, 2009
    5,062
    1,159
    True. Maybe I will do both then.
  13. #12
    Nov 30, 2010
    16,655
    7,293
    Yes. A flat on the shaft has saved many a drill bit for me.
    But you might use a grinder. Tool steel (drill bits) can be difficult to file.
    If you're on a motor shaft, that's, "mild steel". A file will work.
  14. MaxHeadRoom
    Jul 18, 2013
    10,813
    2,491
    You can also get Allen set screws with a pointed end they grip better than the flat ended style.
    Max.
  15. Lestraveled
    May 19, 2014
    1,957
    1,217
    @spinnaker
    I always did think you had a screw loose.:D
  16. shteii01
    Feb 19, 2010
    3,496
    511
    Prepare to get pie in the face.
  17. kubeek
    Sep 20, 2005
    4,686
    805
    Better loose screw than loose wire ;)
    JoeJester, spinnaker and #12 like this.
  18. spinnaker
    Oct 29, 2009
    5,062
    1,159
    That is what these are.
    Actually just look at them again . They are mode flat. Where do I get the ones with the point? How would I know what size to use?
    What are they actually called?
  19. spinnaker
    Oct 29, 2009
    5,062
    1,159
  20. cmartinez
    Jan 17, 2007
    3,695
    2,746
    The only way to loosen a bolt that's been locked with red loctite is to heat the part with a small torch.
    I like using the type used for cooking desserts, like creme bruilé
