Servo Motors and Centering
Discussion in 'General Electronics Chat' started by jproject, Jul 9, 2011.
  1. jproject
    May 12, 2011
    17
    Hello everyone,
    I was wondering if there is a way to center the servo motor any way without using a sensor and when I mean centering, I mean a certain side always facing the front, not centering as in configuring to get the servo to stop moving at a certain pulse width. Here is the servo motor I am using: Parallax (Futaba) Continuous Rotation Servo
    and here is a link to the manual of the motor:
    http://www.parallax.com/Portals/0/Downloads/docs/prod/motors/900-00008-CRServo-v2.1.pdf
    I will be attaching an 80 cm distance sensor on the servo motor as well.
    Thank you.
  2. praondevou
    Jul 9, 2011
    2,936
    489
    I don't think it's possible to do this without any sensor. Your microcontroller will be controlling the PWM and if you want to stop the motor at a certain point, you will have to give the controller an information about its position. However, once you somehow attach a distance sensor to your motor you WILL have this information. Once you calibrated it, you can always stop your motor at the same position.
  3. jproject
    May 12, 2011
    17
    Hm... it looks like I'll be adding a line sensor at the bottom of my turning component and draw a white line at the bottom on a black surface to pin point the center for the servo motor. Anyone have better ideas?
  4. Markd77
    Sep 7, 2009
    2,803
    594
    How about using a normal servo and a couple of gears if you want something that is capable of rotating 180 degrees either side of centre.
  5. jproject
    May 12, 2011
    17
    Normal servo? Can you give me an example. Also, I am very limited in space.
  6. Markd77
    Sep 7, 2009
    2,803
    594
  7. jproject
    May 12, 2011
    17
  8. Markd77
    Sep 7, 2009
    2,803
    594
