Servo-Motor with 555 timer
PsySc0rpi0n
Joined Mar 4, 2014
1,773
Ok, I need to control a servo-motor with this 555 timer. This is for a school assignment, as usual!
I'm using the 2 diodes version of the astable mode 555 schematic!
So, we were told to consider that the servo-motor turns left for output pulses with tON = 1ms, centered for output pulses of tON= 1.5ms and it turns right for pulses with tON = 2ms and a frequency of 50Hz! We have a 100nF capacitor to work with!
So, as I'm using the 2 diodes version, to be able to get Duty Cycles under 50%, the formulas I'm using for tON and tOFF are:
tON = ln(2)xRaxC
tOFF = ln2xRbxC
So, for 50Hz we have 20ms period.
To get 1ms of tON:
1ms = ln(2)xRax100nF
Ra = 14.4kΩ
To get the tOFF time:
20ms - tON = ln (2)xRbx100nF
Rb = 274kΩ
I'm using a potentiometer for Ra and I'm setting it to 14.4kΩ. Rb is fixed at 274kΩ but I don't know why, I'm not even getting the 50Hz frequency I was expecting. Also tON is larger than expected as also the tOFF.
When you are setting Ra with the potentiometer, to 14.4 kOhm, do you need to connect the remaining portion, the 85.6 kOhm, to ground? If you do not need that remaining portion of the potentiometer, you can leave the end, the third pin, unconnected. Leaving the end unconnected, or floating, will create an open circuit, i.e. no current, through the 85.6 kOhm portion and it will not interact with the circuit.
Leaving the third pin connected to ground will draw some of the current you expect to charge and discharge the capacitor and direct it to ground.
PsySc0rpi0n
Joined Mar 4, 2014
1,773
But I think LTSpice will complain about having a floating node! Let me try!
Edited;
I'm still getting 23ms period and 1.2ms of tON. I don't know if those 3ms and 0.2ms from period and tON are from LTSpice modulation or if it is still something wrong! Will the servo-motor still work correctly with those values?
If LTSpice complains, I do not think it should, then connect the third connection of the potentiometer to the middle wiper instead of leaving it floating. That way the 85.6 kOhm portion is connected to same voltage on both sides and, again, no current will flow through it.
Here is my guess. The equations do not compensate for voltage drops across the diodes and will therefore give you some error in the final times.
The voltage drops across the diodes will be about 0.7 volts when conducting current. This reduces expected current charging and discharging capacitor. That reduction in current will result in longer times. 10 - 15 % seems reasonable.
ericgibbs
Joined Jan 29, 2010
18,872
hi Psy,
Hint: Having two diodes is causing you those problems, try with just one diode across the Rb resistor. [remove D2]
E
PsySc0rpi0n
Joined Mar 4, 2014
1,773
hi Psy,
E
Thanks EricGibbs.
By now I have this part of the assignment ready. I have explained that the difference between calcs and LTSpice simulation is due to the usage of 2 diodes that implies a 2 times 0.7V additional voltage drop which is affecting the capacitor charge timings!
ericgibbs
Joined Jan 29, 2010
18,872
Morning Psy,
Here are the LTS sim asc file and plots.
With this very basic 555 timer circuit you will get a slight frequency variation in the frame frequency of 50hZ when the ON period is adjusted, this will not cause any problems in a practical servo application.
E
