Servo motor used as a stepper motor
Discussion in 'General Electronics Chat' started by Manmeet Singh, Dec 21, 2010.
  1. Manmeet Singh
    Thread Starter Active Member
    May 21, 2008
    37
    Hello all I have been working on a project in which I would like to minimize cost and have found that the stepper motor is accounting for a large portion of that cost. What im wondering is can I achieve the same functionality using a servo as I would a stepper motor? My needs are I want to be able to rotate with 45 degree increments 360 degrees nothing more both clockwise and counterclockwise. Any thoughts on the topic would be appreciated
  2. #12
    Nov 30, 2010
    16,685
    7,322
    You will have to devise a system to tell the driver when to stop (because you have arrived at 45 degrees etc). That's about all I can think of.
  3. djsfantasi
    Apr 11, 2010
    2,905
    878
    What type of servo motor are you considering? Most hobbyist servo motors will only rotate 180 degrees, without modification. They can be modified for full rotation, but then you lose positional control, i.e. either rotate clockwise, stop, or rotate conterclockwise.
  4. Manmeet Singh
    May 21, 2008
    37
    I was intending on using a cheap hobbyist servo motor and modifying it but wasnt sure about if I would lose positional control. Lets say positional control is not critical could I still effectively use a hobbyist servo to rotate 360 degrees and turn with 45 degree increments?
    As a seperate question if I stop issuing the PWM signal to the servo does it swing back to neutral position?
  5. Markd77
    Sep 7, 2009
    2,803
    594
    You could add gears to make the 180 into 360. It wouldn't be able to rotate continuously but it could point in any direction.
  6. djsfantasi
    Apr 11, 2010
    2,905
    878
    No, if you stop sending the PWM signal, the servo will NOT swing back to its neutral position. It will basically be uncontrolled and may be moved by any external forces. Here is some information on hobbyist servos:
    http://www.lynxmotion.com/images/html/servo01.htm.
    Markd77's suggestion of adding additional gearing has been done. Just remember that even with that solution, you can only rotate 360° in one direction, then 360° back - no continuous rotation.
  7. jpanhalt
    Jan 18, 2008
    5,699
    909
    Gearing is one solution. You might also consider one of the newer servos that uses a rotary encoder. They are claimed to be extremely precise, and since there is no pot, there is no theoretical reason they cannot rotate 360° or more. I have not seen ads for ones that go more than 360°, but here are links to ones that will move 360°.
    http://www.shanghaiinspection.com/D...recision-High-Torque-Metal-Gear-Servo-p-24683
    http://www.ltair.com/en/productlist.php?intClassID=50
    As mentioned, the signal to a model servo needs to be continuous.
    John
  8. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Are you using a microcontroller in your current design?
  9. shortbus
    Sep 30, 2009
    4,095
    1,681
