Servo motor for a reflow controller
electrophile
Joined Aug 30, 2013
167
This may seem like a very broad question but here goes. I'm trying to select a servo motor that pushes a reflow oven's door open to aid the cooling process. Can anybody help me understand how much torque would be needed to tip the door open.
Alec_t
Joined Sep 17, 2013
14,280
My crystal ball has misted over.
How heavy is the door? What dimensions? Top-hinged or side-hinged? Latching mechanism? Spring-loaded? Power supply?
MaxHeadRoom
Joined Jul 18, 2013
28,618
You can measure it with a spring scale for e.g.
If you want precise positioning for temp. control using a servo motor you would need feedback via PID loop.
Depends how precise you need it.
Max.
electrophile
Joined Aug 30, 2013
167
Ah well! Lets see... Door is about 12" x 7", bottom hinged (on the long edge), spring loaded. Power supply is a 5V 2A wall wart.
Max.
Don't really need much precision actually. The servo just opens the door to cool the oven a little faster and once the temp reaches a certain point it releases and the 'ajar' door shuts back. The software monitors the temp and controls the servo. I'm wondering if I should just open the door manually to cool it :)
