Servo Limit Switch
Discussion in 'General Electronics Chat' started by tm585, Mar 15, 2007.
  1. tm585
    Mar 8, 2007
    6
    I am made a pan /tilt cam using two servos. One is a standard servo for the tilt the other is a continuous rotation servo for the pan. I want to set a limit to keep it from turning round and round and messing up my wires.I want it to go just shy of 360 degrees. I plan on driving the servos from a servo testing circuit I can make . Which works great.But I need to figure the limit switching out by using 2 micro switches. I know of a way to do it usig a stamp2 but I really dont have enough of them to waste on being installed inside. Any thoughts? Thanks for any help.
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    If you share a schematic of your current setup, we should be able to point out where the microswitches can go.
