Servo control using ATtiny13
Discussion in 'Embedded Systems and Microcontrollers' started by lorikyo, Mar 10, 2009.
  1. lorikyo
    Mar 10, 2009
    How do you control a Hitec servo that has been modified to rotate 360 degrees using pwm from ATtiny13?
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Can you provide a part number for the servo so that we can look up the manufacturer's datasheet on the device?
    hgmjr
  3. HarveyH42
    Jul 22, 2007
    425
    5
    Guessing... a pulse width of 1.5 ms is the center, so above or below should determine the direction of rotation...
