Servo control for a tonearm
Discussion in 'The Projects Forum' started by Straight Tracker, Mar 15, 2013.
  1. Straight Tracker
    Mar 11, 2013
    Hello All,
    I designed and built a servo controlled tone arm in 2012 and am looking for someone to design the servo circuitry for me. I cannot afford to pay for that service and am looking for an individual who will take precision milling machine work and/or CAD drafting/3D solid modelling in trade.
    I can do the prototyping and PCB work myself.
    I intend to use a 10mm diameter stepping motor to drive the tone arm carriage, controlled by a linear analog Hall Effect device in a closed loop configuration. I did something similar in the eighties using TTL logic ICs. However, I would like this new circuit to use a microcontroller to reduce the parts count. The circuit also includes digital Hall Effect switches and several push buttons.
    I can supply a block diagram and spec sheets for the various components which I already have.
    Sincerely,
    Ralf
