Service manual Technics SX-AX7 Keyboard
Discussion in 'General Electronics Chat' started by grauerWolf60, Feb 12, 2016.
  1. grauerWolf60
    Feb 10, 2016
    8
    i am new one. I search the complete service manual for the technics sa-sx7 synthesizer. can you help.
    The keyboard has no function. Only LCD background is lightning. I believe the power supply are damaged.
    Wolfgang
  2. grauerWolf60
    Feb 10, 2016
    8
    Sorry
    read correctly: SX-AX7 Synthesizer
  3. Dodgydave
    Jun 22, 2012
    5,167
    777
    You have to download it from Technics.com, create a login member.
  4. grauerWolf60
    Feb 10, 2016
    8
    Sorry
    the sx-ax7 synthesizer is not found. I need the service manual not the user manual.
    it doesn´t matter whether registrated or not. Nothing with ax7 or SX-AX7 is found on this site.
  5. absf
    Dec 29, 2010
    1,493
    374
  6. grauerWolf60
    Feb 10, 2016
    8
  7. grauerWolf60
    Feb 10, 2016
    8
    Hi bertus,
    i have a mistake in the thread heading and I get wrong replys. I tried to open no 2. thread but no possibility to close the thread. The correct name of the synthesizer is technics SX-AX7 instead of SA-SX7
  8. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  9. grauerWolf60
    Feb 10, 2016
    8
    Thanks for changing.
    after measuring power supply the dc dc converter has a problem. The coil has 0,8uH and the 100Ohm resistor is very hot.At load the 5V falls to 2.4V.
    I guess not enough power is supplied. Perhaps anywhere had a wiring plan on power supply.
