Series RLC circuit connected to AC voltage generator.
Discussion in 'Homework Help' started by cdummie, Mar 27, 2016.
  1. cdummie
    Feb 6, 2015
    104
    So i have RLC circuit where R, L and C parameters are known, this circuit is connected to ideal AC voltage generator with effective value of voltage E. Find all the values of angular frequency for which effective value of current in the circuit is equal to Imax/sqrt(2) where Imax=E/R is maximal effective value of current in the moments when this circuit is in resonant frequency.
    Now, when it comes to resonant frequency is relatively simple, since that is the frequency when impedance is lowest possible. Impedance here is Z=R+ j(ωL - 1/(ωC)) it means that lowest value of impedance will be when ωL=1/(ωC) or
    ω=1/sqrt(LC) or f=1/(2πsqrt(LC)) and that's what's going on with frequency when we have maximal value of current, but how can i find frequencies (i believe there should be two frequencies where I=Imax/sqrt(2)) such that they satisfy the requirement of this example.
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
    Can you explain why two (real) frequency ??
  3. cdummie
    Feb 6, 2015
    104
    Well, i think because resonant frequency exists, there has to be frequency where I=Imax/sqrt(2) before we reach the resonant frequency and the one after we reach resonant frequency when current starts decreasing.
  4. Jony130
    Feb 17, 2009
    3,990
    1,115
