Series Resonance Help
Discussion in 'Homework Help' started by trav, Dec 8, 2011.
  1. trav
    Dec 8, 2011
    7
    Connect the 50 Ω output from the function generator to the oscilloscope input and establish a sine wave on the oscilloscope with the following characteristics:
    a. f = 100 Hz, Vmax = 500 mV
    Disconnect the output of the function generator from the oscilloscope and apply it to your circuit.
    Giving me the result:
    f(hz) Vr(V) vc(V) vl(V)
    100 0.96 0.65 0.06
    150 0.13 0.63 0.08
    It then asks me to use these results to calculate the following parametersfor 100 and 150hz:
    I (A)
    XL (Ω)
    XC (Ω)
    Z (Ω)
    How do i do this?
  2. who_me_yes_you
    Dec 7, 2011
    8
    Ohms law my friend...and depending on whether you know the values of capacitance, inductance and resistance and have a basic knowledge of complex numers this is how it is calculated
    Vr + Vc + Vl = total voltage (Vt)
    Xl = jwl=2*pi*f*l
    Xc=jwc=2*pi*f*c
    Z=R+(jwl-jwc)
    It = Vt/Z
  3. crutschow
    Mar 14, 2008
    13,472
    3,359
    You only need ohms law to calculate the various impedances. Since you know that the currents are the same in all devices for a series circuit, it's a simple matter to calculate each impedance knowing the current through, and the voltage across, each impedance.
  4. trav
    Dec 8, 2011
    7
    Would i be right in saying:
    1. I v/r 0.0957/100
    2. Xl = 2pi x f x l
    3. Xc = 1/2pi x f x c
    4. Z = √rsquared+(Xc-Xl)squared
    5. tan-1(Xc-Xl)/R
    I think im right here but would like some clarification especially with the first one of all things lol
  5. Adjuster
    Dec 26, 2010
    2,147
    300
    In your first post, you had Vr(V)=0.96. Now it seems to be 0.0957. Which is it to be?
  6. trav
    Dec 8, 2011
    7
    0.096 sorry my mistake but thats not really my issue here. More intrested in the formulas being correct.
  7. trav
    Dec 8, 2011
    7
    Forgot to mention a 100ohm resistor was used and thats were im taking my 100 figure from in Q1
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
    After you get it sorted out in your head figure out the voltage the components are dropping. I love to give this question to beginners, because the results are so surprising.
  9. t_n_k
    Mar 6, 2009
    5,448
    783
    Interestingly, the experimental procedure seemed to make no directive to the student to adjust the generator frequency in order to find the series resonance condition.
    Is the OP aware of the measurement indication(s) of when resonance has actually occurred?
