Series Regulator circuit question
Discussion in 'Homework Help' started by PonkPonk, Oct 19, 2012.
  1. PonkPonk
    Sep 11, 2012
    7
    Hey good folks!
    Consider this circuit..
    http://upload.wikimedia.org/wikipedia/commons/9/9f/Voltage_stabiliser_OA.png
    What I want to ask is what the Rv resistor does - is this the same as with calculating Rs for a regular Zener diode?
    My textbook doesn't explain this, but it should be very simple since they are in parallell.
    Is this correct interpretation?
    Thank you for your help!
  2. WBahn
    Mar 31, 2012
    18,089
    4,917
    Since what are in parallel?
    Q1) What purpose does the series resistor serve in a simple zener-based regulator?
    Q2) What is the purpose/meaning of the voltage at the negative input of the op-amp?
    Q3) What would happen if the Rv resistor were removed (open circuit)?
    Q4) What would happen if the Rv resistor were shorted?
